Will not start, please read on for details....
Wow, Im a new owner to a 92 5.0 lx and I really did not want my first post to be about this but here go's, any input is greatly appreciated. I search for any similar cases such as mine and no luck...
I cleaned my engine bay this morning (sprayed degreaser then sprayed with a normal water hose) and gathered a lot of info on here just to double check I was not going to hurt anything before I did it. I usually do this by hand on my previous cars without spraying but this particular mustang has been neglected cleaning wise and I figured I would spray it down first. Ive had it about a week now and no problems what so ever so far until this.
Now it wont start, it will crank on me but not fire up.
I covered the battery, altinator and all ignition components.
I dont see how I could of got water into the engine, being it is sealed up.
I checked to make sure no fittings, vaccum lines, or any connections were sprayed loose. I did not use a pressure washer anyway just a garden hose.
Any suggestions are greatly appreciated please go ahead. If you need any more info to help please ask.
Have a good day everyone,(at least have a better one than mine right now)
RE: Will not start, please read on for details....
Thanks for the tips guys. Well since my last post, I got it to start a few times. But it was running rough, took it for a drive down the street and it was sputtering backfiring and bogging out. let it idle for a while turned it off and now it will not start again.
A little bit of more info: I recently took off the upper intake maifold to strip it and return it to stock (I had to paint it silver, I was striping and grinding for 2 days. There was like 3 past diffrent paint jobs on the thing because it was painted in some god awful black metal flake and who knows what else). I took note of the vaccum hose locations and to my knowlege they should all be installed in they're right location. I started it once and let it idle for some time(which at the this point it was fine) after I re intalled the upper iintake manifold (a few hours before) before I de-greased the engine. Could it be I have some of the vaccum hoses in the wrong location and that is causing this problem? I could provide pics to show everyone the current locations of the lines if anyone thinks that may be the problem.
Thanks for all the help.
MEISTERSNFB
03-31-2020 07:50 AM
