Cobra intake install questions
My buddy is giving me his polishedcobra intake. After swapping out my stock intake and putting this polished one on do I have to do anything else to make it run right? Any re- programming or anything ....adjustments I need to make?
Thanks
Thanks
RE: Cobra intake install questions
Its pretty straight forward. No adjustments you really need to do after it is installed. Stock throttle body and maf will work, I would recomment upgrading at least the throttle body though.
Upgrading the TB won't do much for you if you're still running the stock 55mm MAF. Find a larger MAF and you'll be good. Stock heads don't use all the stock TB has to offer anyway.
Diode Dynamics
28
05-26-2022 12:02 PM
