5speed trans problem help!
well guys im a newbie great site. i have an 89 vert lx 5.0 with a 5 speed trans. now my problem is when i shift in high rpm from 2nd to 3rd it will girind now yesturday i changed the fluid out and adjusted the cable and it hasnt done it again BUT it still has a whine sound. my car sounds like if it has a whipple!
RE: 5speed trans problem help!
synchro's are worn
don't sweat it it too much, worst case scenario is if you continue to powershift it, it will get harder to go in gear.
as far as the trans itself, it's fine
it will do it more when it's cold too, so let it warm up b4 thrashing it
gear mesh probably
i'm sure your due for a rebuild sooner or later , but like i said, it's not that big of a deal until you break something, or it stops going into gear , which it should be far from that
ORIGINAL: 5.0 lou
1st... the wine... if you have a short throw shifter thats causing it, its not deadening the sound like the stocker does.... even if it is stock, its not amything to worry abuot
as for the grind... its your 3rd gear syncro going out... i no they told u not a big deal, but if u wanna keep shifting quick u should look into a rebuild soon(pm 94gtcoupe, he rebuilds them for cheap, and knows his ****). what will happen is it will get worse and worse and worse and before you know it you will be having to match up rpms to put it in 3rd.
