rockers
Old 10-21-2004, 06:22 AM
cammedlx
cammedlx's Avatar
Default RE: rockers
well many people don't just have the money to buy a set of heads so i figuerd i would atlest through either a b or e cam in there or something similar so the only thing i have to do is tighten them down to spec and thats it
cammedlx is offline
Old 10-21-2004, 06:31 AM
92BOOSTED
92BOOSTED's Avatar
Default RE: rockers
I ran the "e" cam in my car with stock heads and it ran well, 13.6 plus it still got good mileage.
Rye
92BOOSTED is offline
Old 10-21-2004, 07:06 AM
cammedlx
cammedlx's Avatar
Default RE: rockers
yeah i know i did'nt ask if i need heads or what type of cam i was just asking how to adjust the rockers after i do the cam install im not a moron i know alot about car mostly chevys and i did'nt know if you had to adjust the valve's the same way you do the chevy and for the one's that anwsered my the question that was asked thanks and for the one's that did'nt you did not help at all [8D]
cammedlx is offline
Old 10-21-2004, 01:08 PM
roundman
roundman's Avatar
Default RE: rockers
you ought to know by now that you can't ask a question on here without getting lots of unsolicited advice along with some good and some bad answers to the original question. LOL the hard part is trying to recognize the bad answers!!!!
roundman is offline
Old 10-21-2004, 09:10 PM
vfast
I ♥ Acer
vfast's Avatar
Default RE: rockers
why not just put on a set of 1.7's to increase lift..much easier to do than a cam swap...
vfast is offline
Old 10-21-2004, 09:18 PM
settled4automatic
settled4automatic's Avatar
Default RE: rockers
what are "a set of 1.7's" ?
settled4automatic is offline
Old 10-21-2004, 10:29 PM
Stinger
Stinger's Avatar
Default RE: rockers
Well never said anyone was stupid. Wasnt trying to insult you and i apologise.
Stinger is offline
Old 10-22-2004, 04:12 AM
cammedlx
cammedlx's Avatar
Default RE: rockers
yeah i know i sorry for being a *** was kinda tired though and as for the increasd ratio rockers would be bout the same but when you crank her up there no better sound than a lumply bumpstick
cammedlx is offline
Old 10-22-2004, 04:19 AM
Aliate X
I ♥ Acer
Aliate X's Avatar
Default RE: rockers
ORIGINAL: roundman
the E7 stock heads use pedestal mounted rocker arms which are simply torqued down to specs. be careful on the cam selection as you could run into a problem with piston to valve clearnance with anything more than about 0.498" total lift at the valve.
What the hell dont you know about 5.0s?, Im going to come up with a question that you cant answer some day.
I thought the stock rockers were stud mounted?? Guess I was wrong.
Aliate X is offline
Old 10-22-2004, 01:33 PM
roundman
roundman's Avatar
Default RE: rockers
ORIGINAL: settled4automatic
rockers arms with a 1.7:1 ratio versus the 1.6 rockers which are basically the stock ones.
they would provide 6.25% more lift at the valve than the 1.6 rockers.
roundman is offline
Sixer4Life
10-12-2015 04:26 AM
69MustangCoupe393cid
10-03-2015 10:33 AM
uedlose
09-30-2015 08:01 AM
Sixer4Life
09-28-2015 07:05 AM
JDWalton
09-24-2015 08:47 PM
Quick Reply: rockers
