how to remove light switch?
well i cant turn off my lights it seems like the switch is stuck or something because this happened all of a sudden. before it worked fine. how do i remove the switch?
RE: how to remove light switch?
which lights ?
the headlight switch that also has the fog light switch. i already pulled the dash but i cant see if they are bolted down. how can i remove it?
anyone? does it just pop out? i dont want to break anything
i think it does just pop out, heres a link that has a step of taking it out. [/align]http://www.corral.net/tech/maintenance/foglights.html[/align][/align]i had to replace mine not to long ago and a buddy ofm ine got mine out without taking any of the other dash peices off, so im sure it does just pop off. but ya if you break it its a $45 part..[/align]
yeah i saw that before and i tried to just pull it out but just comes out from one side. i think it already might be broken since i cant turn the parking lights off.
I popped my switchesout today, just take the bezel off and there are 4 plastic pieces you push in, then the switch will pop out.
what "bezel" is that? so i have to take the plastic pieces off first before i pull the switch?
the bezel is the piece that holds the switches, there are 4 torque head screws to remove the bezel, the clips are behind the bezel.
where are the screws because i cant see them and it seems that it only has two since one side moves already
