alternators electric fans and pulleys
ok i was wondering if the higher amp alternators take more power from the engine to create the amps? i wasnt going to use the alternator underive pulley but can i if i get a bigger alternator. i also want to run an electric fan
RE: alternators electric fans and pulleys
I had the underdrive pulley on my 130 amp alternator and it still didnt charge right until I put the original alternator pulley back on.
BTW- the stock 3G '94 Mustang alternator pulley is the same size as the Fox underdrive pulley.
Are underdrives really worth the $money$?.. if i have a 130amp 3g alt, will charging be a prob... should i use the alt underdrive pulley or still keep the one i got on there now...
Putthe stock 75 amp alternator pulley on the 130 amp alternator.
I was having charging issues with the underdrive pulley on the 130. My headlights were dimming and the gauge was reading below normal at idle. Now its right where it should be and the lights are bright like they should be.
09-25-2015 09:06 AM
