shorties or longtubes
RE: shorties or longtubes
Longtubes will net you more power. As far as sound goes, it's all personal preference. Some people think X-pipes sound better, others think H-pipes sound better. Same thing goes for headers. Sound will deoend on what you like and what your overall setup is.
I like my long tubes i bought bkk off summitracing for $230. just know that if you do the install yourself it will be a pain in the *** and if you have a shop do it chances are it will cost 2 or 3 times the amount the header themselves did. i installed mine and it took about 8 hours and wasnt an easy task. first of all you might as well replace the motor mounts while your at it because they are cheap and you have to pull the motor off the mounts to install anyway. i gained 7hp and 11tq to the rear tires with mine which may not seem worth it but you will definately see more gains in future mods. also they sound great i think but another draw back is that they are a tight fit and sometimes will rub just a little bit on the k member but its up to you. if you dont have much done to the car i wouldjust stick with the shorties
Cobra heads
Cobra intake manifold70mm BBK Throttlebody
C&L Mass Air
E303 cam
BBK cold air
24# injectors
Granetelli alum. race radiator
Flex-a-lite electric fan
BBK longtube headers
BBK mid-pipe
Flowmaster American Thunder 40-series cat-back
3:73 gears
hurst short throw
MSD ignition
kenny brown sub-frame connectors
kenny brown k-member
BBk under-drive pulleys
aluminum drive shaft
17" chrome cobra r with BFG KDW up front and ET street in the rear
277rwhp 314rwtq
Cobra heads
C&L Mass Air
E303 cam
BBK cold air
24# injectors
BBK mid-pipe
3:73 gears
hurst short throw
MSD ignition
277rwhp 314rwtq
ORIGINAL: 88BlueGT
Not true that LT's are only good for high HP cars...
ORIGINAL: 90mustang5.0
LT for lots of horse power, and shorties for avg hp is what i heard
