XFI vs. PMS for first time tuner?
Im getting ready to start my 5yr. project and im looking in to tuners for my 331 76gts turbo project. Im looking at PMS and XFI because they say they are for a first timer. I would like people that have used them to tell me pros and cons. Please. this is what i understand so fare pms mass air, stock computer, 500rpm adjustable. XFI true standalone, 02, I think 200rpm adjst. I know the price differance is $800but I want the one I can undersand the best. sorry for long post. again those that have used one you thoughts please. thank you.
RE: XFI vs. PMS for first time tuner?
another option for you............
use stock EEC computer for Fox Mustang 5.0 ( available new or used )
then use www.tweecer.com to modify for a custom tune.
Tweecer RT is supposed to be very user friendly.
There is also the FAST standalone system.
all these systems require a good bit of knowledge to tune with.
myself I just went to a local dyno tuner and they used
the STC tuner system that they program on site adjusting with
dyno pulls and allows for 4 different tunes to be loaded in,
Street
Strip
Valet
Boost/Spray.
ect. ect.
Street
Strip
Valet
Boost/Spray.
ect. ect.
adder does megasquirt com with all the wiring needed to hook up and how user friendly is it?
r.barn i looked in to tweecer and it take sa lot of research to learn.
but i think they all will take some time to learn. XFI is the newest FAST system.
thank you both for the help!
anyone ever use a FAST / XFI or PMS?
i have the pms in my car. its retardedly simple to use. plus the handheld doubles as a multi function gauge with about 10 different readings on it. with my new motor i plan to get the interacq software so that i can have even more control over my motor. the interacq software allows you to tune the car with your laptop and data log everything the car does: afr, incoming air temp, rpm, water temp, load level, injector duty cycle, injector opening time in milliseconds, degrees of timing,etc. its all recorded and you can play it back unlimited times.
The tweecer seems better suited for guys who want excellent drivability & power AND have curiousity about what Ford did with the EEC-IV.
If you don't care about learning the Ford programming then a stand alone or pms would be a better option.
I have struggled more with learning the Ford system of programming, than I have with learning the tweecer software (CalEdit).
jason
jason
the pms has no settings for ac. the pms wont have any issues tuning a car with ac but you cant modify the way ac works with the pms.......at least on the 5.0 motors you cant
09-01-2015 08:16 PM
