rocker arm help
rocker arm help
hey guys whats up? starting to put my engine together but iam not sure on what rockers to use .Ihave edelbrock performer heads and i know that they are for pedastal mount rockers but iam not sure if i should use pedastal mount or change them to adjustable?i put them toghether once to get my pushrod length but the rockers i used were 1.7 my buddy let me use now i want to do this the right way i need to know what kind of rockers i can use with these heads ? can i use r/r that are pedastal mount or do i have to uy the kit to change them to adjustable this is were iam confused any help would be great. also my car is giong 4 paint at the end of the week i will kep you guy up to date. thanks
RE: rocker arm help
I would use roller rockers their more expensive but you got 2 grand into heads you might as well go all the way. Do you have a factory cam or is it bigger. I used adjustable or stud mount as their also knownon my afr heads but 3 months later one loosened up so I have to take the valve covers off and readjust, but they give you more adjustment for a bigger cam. The pedestal mount are what the mustang came withfactory. You basically just bolt them down and you're done, I don't know a whole lot about the pedestal mount rockers.I had one guy tell me he wished he would have stayed with the pedestal mount but I don't know. If you're going with a bigger cam or chargerI'd spend the money on adjustable, just be ready to do extra work.
