Coolant flush/hopefully more heat...
RE: Coolant flush/hopefully more heat...
ORIGINAL: 2 kwik
go to NAPA and get their rad flusher it's in a plastic blue bottle and get a MR Gasket 180 stat..no other stat just this one...there 8.95 from auto zone
ORIGINAL: 2 kwik
160 is not goodmy friend as it can stay in closed loop hurting perfornace
ORIGINAL: phalcone
it also depends on what kind of heat you are used to , or are looking for .... i have owned a few fox mustangs ... my brother has also.... not one of them made any real hot run you out of the car heat . all you can do is make sure that you have the proper coolant level ... make sure the core isn't clogged , & controls are working.... also make sure the fan clutch is working properly ... if you have a frozen clutch on the fan its like having a direct drive fan , & that will keep it cool also.....putting a 180 therm is gonna make the heat cooler i can tell you that..
ORIGINAL: Ninety5five0
Couldnt raelly hurt to do it. It may help, it may not. Either way it'll be new and fresh and you'll have that peace of mind.
If its got a new core its completely possible that someone installed (or made) a special service vehicle heater core resistrictor plug.. I made one out of stainless for mine with a 5/16" (maybe it was 3/8", I don't remember) hole and it certainly does take longer for good heat now. But eventually it does get hot enough to run you out of the car. When it was stock the heat was just as good as anything else I've ever had (except the Jeep.. Its got a crazy hot heater).
