whys the cluch slipping
#21
RE: whys the cluch slipping
Bleed the clutch, then go from there. It will probably at least help, especially if he just put it in. Sometimes it takes a few tries to get all the air out. Pump it, then hold it while a friend loosens the valve to release the airand tightens it back up.
#22
ORIGINAL: Wynn
#25
WOW please don't give transmission or clutch advise anymore... not to be a dick but you don't know what your talking about...
they make kits for mustangs to convert to hydrolic clutch... why u would do this is beyond me since the hydrolic is slower that the cable clutch but to each his owni guess
ORIGINAL: Wynn
ORIGINAL: 87black snake
you can't....you don't have a hydraulic throwout bearing...unless you modified one to fit somehow....
#27
ORIGINAL: burning the tiers
y not its a brand new pretty much clutch y couldnt he bleed it its a new clutch less then a year old
#28
+ 1000 there is not way to bleed a clutch on a mustang unless it has been converted to a hydrolic (very uncommon and dumb IMO)
and burning BECAUSE there isn't any component in a mustangs clutch system tthat uses fluid there for there is nothing tobleed
you don't have a hydraulic clutch...therefor...no fluid in clutch system to bleed....our clutch system works off of forks and cables.....if someone tells you they can bleed a clutch on a mustang.....give him a swift kick in the nuts....
#30
As was said, that car does not have a hydraulic clutch, therefore you cannot bleed it. You can adjust the cable, but no bleeding.
