Low fuel light
RE: Low fuel light
i guess my issue with it is why does the car seem to stumble and not run as smooth as it does when the light is off. So this module has nothing to do with the way teh car runs just whether or not the light comes on or not?
RE: Low fuel light
it could be in your head that the car is running bad with the light on and the modual has to run from the tank to be able to pick up a reading on the low fuel so it is part of the pump in a way its all one big sending unit
RE: Low fuel light
When the light is on teh rpms drop a bit and then itll idle up then drop back down. I figured that it has to be something with the pump not putting out enough and that is where the stumble i feel comes from
RE: Low fuel light
ORIGINAL: 06Rubi
does anyone know what the fuel pressure should be and how hard is it to test? Sorry this is my first mustang and fuel injected toy
RE: Low fuel light
ORIGINAL: 93 LX FiveO
honestly.. i would just pull the bulb. they stopped putting those lights in these cars for a reason... if ur lookin at the gas gauge u aint havin fun
RE: Low fuel light
When i bought the car it wasnt on but only had a little gas in it so i put gas in it drove it home and no light. The car did sit for quite a while without beign driven too much so i thought maybe i just had some bad gas so i added stuff to take water out of the gas. To test it i just need to get to test guage from like autozone and screw it into that schrader valve and turn over the car or how do i go about that?
RE: Low fuel light
Install gauge to schrader valve, start the engine, pressure should be 30-40 psi with vacuum line attached to the fuel press. regulator and 40-45 psi with vacuum line disconnected from the FPR....you may also want to check the ground strap connected behind one of the cylinder heads to the firewall....that ground could also cause some problems.
