Your crossmember is in the way. If you unbolt the mounts and jack the engine up a bit you might be able to get it off, but your oil pump might be in the way. If so, then do the mount/motor thing and you'll be able to access the oil pump bolts. 3 of them I believe. Undo those and let the pump fall into the pan, and then it will slide out
