going from 5.0 FI to carbed
What do i have to change? I know I will have to put the older timing cover on to bolt the fuel pump on but will the roller that is on the end of the cam bolt on the the newer 302?
RE: going from 5.0 FI to carbed
just get a holley red fuel pump and you dont have to worry about changing that i have one on mine i love it
Yea just go with an electric unit, not al the hassle, and they arent that expensive. Obviously you will have to change the intake manifold, and bolt on a carb, other than that and the pump it is pretty much straightforward
your also gunna need a new dizzy
http://www.jason.fletcher.net/tech/e...b/efi-carb.htm
Go to this link... It should help you out a whole lot. Good luck |
thanks for the replies. This is going in a 1984.F150 truck. I was wanting to get a newer motor like what is in the 86 on up mustangs. I see that I will have to change the gear on the distributor gear for the roller cam. So will the older round oil pump drive off my 84 work on the roller cam of the newer engine?
