trans help
trans help
any ideas to why my auto wont go into overdrive when i am over three grand in third. this is my first auto car and its really starting to get on my nerves. its an artcar aod with a 2800 stall
RE: trans help
have you checked your transmission linkage on your throttle body. It should be the linkage closest to the passenger side strut tower. Make sure it hasn't fallen off, if so immediately replace it, if not the throttle pressure may need to be adjusted.
RE: trans help
if the over drive band was shot it wouldnt work at all. it works just fine just wont go in over 3000 rpm. how do you ajust the throttle pressure. and i replaced the shift cable how do i ajust that as well
Matt's 95 Stang
10-05-2015 07:16 AM
