Sealing nitrous nozzle
I installed my NOS dry kit today. I could not find the right tap, so i used one that was VERY close. The man at the hardware store said with some thread tape it would seal. My question is, is with the nozzle installed there is a LITTLE play. Obviously it is not sealed totally and i was going to put some epoxy, or RTV to seal off the nozzle. Would this be a good idea? I have been to 5 different hardware stores in town and none of them have the tap i need, plus i really dont feel like drilling another hole in my throttle body. Also, the nozzle is installed in the TB after the MAF just like the directions say. How does the computer know to add fuel since the MAF is not reading the extra O2 coming in?
I tried posting in the pipes, boost and juice section but that place is dead, especially this late. Anyone got any thoughts?
RE: Sealing nitrous nozzle
ORIGINAL: nmerrill
My question is, is with the nozzle installed there is a LITTLE play....
Just curious why you drilled into the TB with a dry kit?
most of the nitrous companies sell threaded bungs that can be used to thread the fogger nozzles into intake elbows. IMO, replacing the upper elbow on an intake because of the drilled hole it has in itis a lot less cheaper than replacing a TB with a hole in it if you ever decide to remove, upgrade, or replace your nitrous system.
ORIGINAL: 65mojoe
most of the nitrous companies sell threaded bungs that can be used to thread the fogger nozzles into intake elbows. IMO, replacing the upper elbow on an intake because of the drilled hole it has in it is a lot less cheaper than replacing a TB with a hole in it if you ever decide to remove, upgrade, or replace your nitrous system.
