Tips on installing a Fuel Line Shutoff Valve
http://www.jegs.com/webapp/wcs/store...0002_761341_-1
I'd like to install one of these " Earls Valves " to be used forsecurity mostly..
Whats the bestplace to plumb one of these in..
any ideas greatly appreciated !
thanks,
Alan
thanks,
Alan
RE: Tips on installing a Fuel Line Shutoff Valve
BUMP ^ Anyone ? Anyone help a NOOOOBIE ?
What I'm looking for here reallyare the fuel "hose" locations on these Fox Body's where I could installa ****** hose endcutoff valve with ...Too cold to get under it today allthough I peeked under thegas tank where the fuel filter is & noticed some fuel hose there.. Oh well
i would wire up an ignition cutoff instead. a lot easier to do and you wont have to crawl under the car to activate it. if you really want to cut off fuel, wire up a switch that kills the power to the fuel pump relay. now with the flip of a switch (or two) your car has no fuel and no spark
What I was thinking of doing is both, I was going to go with a kill switchtapped into the coil or somewhere else in the ignition ormaybe even tapping into the fuel pump ground wire as you guys suggested& the fuel line cut off valve.
Installing the valve cant be any harder then installing an inline fuel filter..
It's maybe a little heavier, maybe I can mount it ..
I think it would really help with security, not to be used everytime I stop @ 7-11 but overnight & long term storage, ect..
I'mmm not sure what I'm going to do...I did order a simple kill switch couple days ago, so I'll start there..
Thanks for chiming in,
Alan
Alan
YoungStangsMan
09-05-2015 07:01 PM
Calizic
08-28-2015 01:46 PM
