PMS question
#21
RE: PMS question
ORIGINAL: AdderMk2
you dont even have to put it together... you can buy them pre-assembled
ORIGINAL: CrazyCobraSpeed
honestly it seems megasquirt is better... but if u dont ahve major goals and u are gettin a hell of a deal the PMS it mite be a better way to go.. i mean its supposta be hella easy... like 12 year old can use it... lol mega squirt is better tho... its just if ur willing to take the time to put it together and learn how it works
#22
RE: PMS question
ACTUALLY.......
you can hard wire the wideband directly into your megasquirt. It will work similar to how the stock ECM uses the stock narrow band O2 sensors, except it will use the wideband for better resolution.
The megasquirt also has a "auto-tune" function, which it can use to adjust your VE (vlumetric efficientcy) tables based on a preset AFR table that you make, and the wideband O2 sensors readings
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
