Smog Pump
RE: Smog Pump
Step 1: Disconnect battery, then remove fan, w/p pulley, tensioner, belt.
Step 2: Remove charcoal canister and smog pump and all lines goig to and from it. All lines going to this must essentially be removed or plugged so to not create a vaccum leak. Most of them you can rmeove to an extent to clean things up. You will leave the alternator and it's mounting bracket in place the entire time.
Step 3: Discharge A/C, then use a/c line specialty tool (a few bucks at parts store) to unhook all a/c lines.
Step 4: Remove a/c condensor and compressor and attaching brackets. you will also be required to unbolt the power steering pump when you take the a/c bracket off.
Step 5: Reinstall power steering pump, but you need to use an a/c delete bracket from ford racing. (I have one for sale if you need one.)
Step 6: Reinstall waterpump pulley, fan, tensioner, new belt that is much shorter (I think 72.5"), could be wrong though. I'll have to check my old one tomorrow.
RE: Smog Pump
can you delete smog and AC (with reposistioned power steering) and run a belt without any pulleys to replace either of the 2?
and if you could check on that belt size that would be great because i am about to do the same thing.
how do you discharge the A/C?
oh yeah and how much for that a/c delete bracket shipped to ohio (44333)?
RE: Smog Pump
ORIGINAL: deanzawistowski
what do you reccommend to plug the lines with?
