pro-m mass vs. c&l mass
hey guys i have a cai set up right now and im plannin on getting either a 73mm c&l maf, or a 75mm pro-m maf. and suggestions, on which one will work better? car is mostly stock, it has full exhaust and a gt40 intake.
RE: pro-m mass vs. c&l mass
ORIGINAL: 9165pt0
Go to the j/y and find a MAF/MAS from a 94-95 Mustang.
The housing is 70mm, and it will function properly with your computer.
You will also have to find an adapter for the inlet hose, as the 94-95 Mustang used a bolt on inlet tube.
Here is a list of potential sources for the adapter.
Here is a Stangnet.com thread on fitting the sn95 MAF on a Fox Mustang.
http://forums.stangnet.com/showthread.php?t=616246
Here is a source for the 70mm Adapter Flange needed for a Fox.
http://www.kustomz.com/
This site has some dyno testing for a couple of common MAF setups…
http://www.secondstreetspeed.com/art.../mass_heir.htm
Photo comparison of a few MAF meters…
http://www.veryuseful.com/mustang/te...ox-LMAF-94.jpg
Some MAF connectors and other plugs…
http://rjminjectiontech.com/?p=10
MAF Adapters and Harnesses
http://www.blueovalchips.com/mafadapter.php
90mm MAF and Adapter
http://www.modulardepot.com/advanced...words=90mm+maf
Discussion of Ford MAF plugs
http://www.blueovalchips.com/index.php?action=mafupgrade
http://teamjdm.com/shop/advanced_sea...words=90mm+maf
Here is their 90mm MAF Adapter
http://www.teamjdm.com/shop/product_...products_id=18
90mm MAF and Adapter / How to
http://www.lasotaracing.com/Late%20model%20maf.html
Some other various MAF Adapters
http://www.kustomz.com/cat3.html
