A/C Delete
A/C Delete
Ok, im putting on my long tubes and deleteing my smog pump. besides a shorter belt what all do I need to delete my a/c. I dont just want to bypass it. i want the pump and all the lines out of the car.I have a vert so you dont really need a/c.
RE: A/C Delete
a/ c is one of the best inventions, why would you want to take it out. im experienced in this catagory..... unfortunatly, and im putting mine back in!!! F the hot weather. haha. but ofcourse mine is a DD so i try to keep it all working well.
oh, and i think you can just get a shorter belt... i think.
RE: A/C Delete
ORIGINAL: smokesricers
Buy an AC delete kit from summit or somethin you get two brackets usually and you move your PS pump up to where the AC was. Its Easy
Also 95droptop, you can remove the crossover tube from the back of the heads and install a 5/8"-11 bolt into the thermactor hole. Install one per head.
if your not sure what im talking about... when you look on the back side of the heads, youll see the tube im talking about!
RE: A/C Delete
ORIGINAL: Goosepoop302
those are the ac bracket holes?? i know which ones you mean but i rember my smog pump going into the back of the head and having a cross bar.
the smog pump as a rossover tube that runs between the two heads ON THE BACK OF THE MOTOR.
when you remove this crossover tube, yu must plug the holes that are now exposed on the back of the heads. they are threaded... and a 5/8-11 bolt fits in them... you want the bolt to be no longer then 3/4"
RE: A/C Delete
ORIGINAL: 2 kwik
removing the a/c will give you about 1 horsepower
