bucking, hesitating, backfiring...
yeah, like the title says. my car hesitates on acceleration (but not always) and drinving down the road it pops/backfires whether holding a steady rpm, accelerating, or decerlating. every time it does so the tack jumps around and then goes back to where it was. this happens over the entire rpm range.
it does this in intervals of seconds with no pattern that i can figure out.
since the tach jumps around everytime this happens i would guess its something electrial, but i have no clue where to look.
help please its almost undrivable
RE: bucking, hesitating, backfiring...
it happened about two times coming home from the gym and then the next time i drove it it started doing it more frequently, so pretty much out of nowhere.
a tune up was done a few thousand miles ago: new plugs, cap/rotor, fuel filter.
oil change was done like 200 miles ago.
i thought i might have too much timing, i have to run 93 to keep from pinging (i set it like that on purpose) so i pulled the spout plug but it made no difference.
the timing has been set like that for months and months though...
the plug wires are kinda old (almost two years) and they are ford racing 9mm. should i go ahead and replace those?
I am having the same problem after 4000 RPM, i am fearing that its a timing chain because I dont wanna take it apart untill I am ready to puta new cam in it...I am going to intstall a new fuel filter soon. I was going to do it yesterday but the 500 was on. It will buck and jerk and hesitate sometimes but when i rev her up to 4000 she starts popping and backfiring and i lose power. Sometimes it even pings.
it deff sounds like you messed up your firing order thats what mine did when i messed it up had two wires switched around at idle it sounded like it had a monster cam then when i would start driving bam bam bam bam bam out the exhuast with hesitation
ORIGINAL: HACKGT350
I have the same issue as the OP, I plan to get new wires and plugs soon.
Swirl
