damn thing caught fire
I was driving back to work from lunch, and I started smelling something burning. Then the interior started filling up with smoke. When I pulled over, my alternator was burning, and my ignition coil was smoking. I've been having a problem with my alt., so I assume that was the problem. What I want to know is, would driving with my alt burned out have been the cause of my coil smoking? The way I've figured, the coil trying to send a powerful enough spark to keep the engine running without the power to push the spark cause the coil to smoke? I figure the coil is still good, because the car didn't die. Any clues?
Vic, the proud owner of a viscious money pit!
RE: damn thing caught fire
"Thermal Event with Visual Effects"? (automaker term for fire)
You may have a bad ignition module. If it shorts to ground internally, the current flow through the coil will get out of hand and cook the coil. That's what your module does, but it does it extremely fast. Sometimes that transistor will melt together and stay grounded. It should pop a fuse as well. It would have to take a rather resisted short to ground to get the current high enough to generate that much heat but not high enough to pop the fuse. I've seen it happen though. You got some looking around to do - there is a good reason your coil let the smoke out
that sucks man i wouldnt exactly say it was on fire now my car was on fire got a faulty carb from holley floats got stuck started spitting gas out everywhere and it was up in flames had my hood up while i was trying to start her i look up and the flames where coming out of my hood scoop the hood was white now its this
i had a S-10 one time bad chose kinda the only reason i got it casue i got it for free from my daddy then i was drinvin home from school one day and it went up in flames the carb was leakin gas the that was the end of tha POS!!!!!!!!!! never again will i own a chevy
Okay, well, I pulled off the old alternator. The plug that goes into the top of the alt. was melted. Can anybody tell me how to replace it? I would just use wire connectors, but coming strait off the alt, I don't know if that would handle the currnet. Oh yeah, and where would I get the proper plug? (the long one, not the short one). I've pretty much decided to replace the ignition module, coil, alt, and voltage regulator. Plus that plug if I can find it.
Vic
Vic
