Hp from Gt40 Explorer Heads and intake?
RE: Hp from Gt40 Explorer Heads and intake?
adder is pushing like 270ish to the wheels (on motor)
he has a cobra which already has gt40 heads/intake (cobra and gt40 intake have slight differences)
here are his mods from cardomain:
BBK Equal length shorty headers
BBK O/R X-pipe (no cats)
SLP Loudmouth Catback
Ford Motorsport C Springs
Tokico Gas Shocks/Struts
Ford Motorsport Swaybars
Steeda Camber Caster plates
Kirban Adjustable FPR
Granatelli Motorsports rear upper and lower control arms
CHE Performance Axle Brace
Fender mount CAI
Professional Products 70mm throttle body
Ford Racing underdrive pullies
Hurst Pro Billet short throw shifter
Triple Hook Billet Quadrant
Billet Firewall Adjuster
Steeda Adjustable Clutch Cable
Ford Racing Aluminum Driveshaft
Ford Explorer 31 spline T-lok differential - pending installation
Moser 31 spline axles - pending installation
3.73 FMS Ping and Pinion set - pending installation
AEM 6in1 Wideband Controller
Walbro 255LPH HiOP Fuel Pump
Spec Stage 2 Clutch
Megasquirt 2 v3.0
Rear Seat Delete
ZEX 125 Wet Nitrous Kit-modified
NOS Big Shot injection plate-150 jets
Fender mount CAI
Spec Stage 2 Clutch
Megasquirt 2 v3.0
Rear Seat Delete
well ifu port the heads on the gt40's which usually runs around 500-800 dollars than u can expect to see much more hp than the trick flow top end kit. go to thumper's site, i forget exactly what its called, someone help, but he can do it for a decent price, and then u will have much better heads than trick flow's and the cam is a good cam, the intake is good and have that port matched to the heads and u should c close to 300 wheel from it.
ORIGINAL: ih8chevy
here is thumpers site.... if you gettin a cam u can get a nice package for 1000 bucks plus the cost of gettin gt-40 heads from a junk yard.... and just get a n explorer intake.... no need to port in unless you goin to shot for 500+ rwhp... the exlporer intake can handle nething under that... only other thing u mite wanna do is get the lower intake ported to match the heads... which is like another 75 ... im gettin cam heads p/p and lower p/p with shipping will be less than 1200.... and hte heads will be shipped bak assembled ready to bolt on.... thumper is a good porter to so now worries
Instead of spending $150 on the gt-40's(Guessing there) and then another $800 on the port job, why not just do it right and buy some AFR's????
ORIGINAL: ih8chevy
[quote]ORIGINAL: vt89gtvert
because i can spend 100 on the junkyard gt40s then thumper said he will port the lower gt40 intake and the heads and throw in a cam for 995 shipped back to my house....for afrs its like 1300.........ill still hav another 300 for a nitous kit.
ORIGINAL: CrazyCobraSpeed
ORIGINAL: ih8chevy
