5 lug conversion
5 lug conversion
im about to buy my front 5 lug conversion. im just checking to make sure that at the parts store i should order 92 lincoln mark front rotors and break pads right? and do the bearings for the rotor come with the rotor? if not what bearings will i need?
thanks gary
thanks gary
RE: 5 lug conversion
You will need to buy the bearings separately.
Inner and outer and theyre about $10 each ($40 or so for the 4 you need) and then you will need to buy bearing seals ($10 or so each) for the rear bearings on the rotors (front has the dust cap).
Double check before buying these rotors that your wheels will fit on them. The Lincoln rotors limit your wheel choice considerably.
HRnB
GT350 S550 Tech
12-18-2015 09:35 AM
11-10-2015 11:39 AM
