Can I upgrade my heads?
So I'm considering a set of Thumper heads for my 88. I know a lot of you will say to skip the Thumpers and save up another $600 for aluminum heads, but for now, I won't be doing that. The one thing keeping me from feeling great about upgrading the heads is that my car uses a quart of oil every 1200-1500 miles. As a note, I've heard some people say that their 5.0s have used this amount of oil since brand new. The car runs awesome, and all spark plugs look the same...clean. Let's say my cranking compression is around 165 on all cylinders. Can I feel good about upgrading my heads?
RE: Can I upgrade my heads?
ORIGINAL: mustnglvr
I always feel good about upgrading heads, what about a cam?
ORIGINAL: Jasperstang308
i think it will make a fine upgrade
does it leak oil or actually use it?
my friend just put a supercharger on his gt with over 300k on it
ORIGINAL: Twisted
Thanks Jasper. My apprehension stems from having heard people say that if you put new heads on an old bottom end, it will make the bottom end worse. I can barely see the logic in that, but wanted to get some other opinions. It's a hard question because I don't know if mymotor uses oil because it's worn, or because it came from the factory that way. I guess there's only one way to find out for sure whether putting heads on will be a good idea...try it and see. Anyone have any direct experience with this?
