FIXED-88 GT Blinker flasher me OFF! Can't find!
RE: 88 GT Flasher pissing me OFF! Can't find!
ill bet the switch for the hazzards is bad. mine is bad. and my blinker doesnt work anymore. i can sometimes wiggle the switch back and forth and they will work for a little while i got another switch from the junkyard for 5$
ORIGINAL: 88droptopgt
Can anyone confirm that there is TWO plug in flashers thingys? One for the hazzards and one for the blinkers?
ORIGINAL: PRO50SC
There are. Flip down the glove box and look behind it to the left towards the center of the dash.
I thought there were two flasher units? One for the hazzards and another for the blinkers to work also. I had went and bought a flasher for the blinkers, I THOUGHT, it is must bigger then the one for the hazzards.
My flashers work fine, switch works fine. I pulled the blinker switch today, reconencted wires to it, no shorts I can tell, still no blinkers.
Still no clear reply here, are there TWO flashers, one for the flashers and one for the blinkers??
Try reading my other posts!!!
It was not behind the glove box anywhere that I could see. I will look by the tilt. It is so damn hard to see under there to find ANYTHING. I can't twist and contort like I used tobe able too.
