starter fluid or something like that?
RE: starter fluid or something like that?
ORIGINAL: AlabamaCobra
calling bs...the directions on can say to pour into brake booster killing the motor then continue to pour the remaining contents.
ORIGINAL: kevman41635
it was funny one time my friend poured in sea foam in to brake booster line while it was not running and it hydro locked the motor and bent a rod so then it was time for a rebuild.
i am not lieing i was there when he did it the shop that helped him rebuild it said that it just so happened that a valve was open and it poured in the cyl. and when he went to strat it it jumped one time then would not move so later that day we pulled out the spark plugs and part of the sea foam poured out and they sprayed starter fliud in the cylander and it finally would run but it sounded like it was about to fly apart. So when they tore it down there wasa bent rod.
So no i did not lie and it is not bs
i know that but when he did that it filled just one cyl. and when tryed to start it. It locked it up. it was on a 4.3 and i might be able to get a picture of the rod if you want it
jwog666
12-27-2021 08:09 PM
logan409
09-26-2015 07:43 PM
09-25-2015 06:42 PM
