302 rebuild questions
So Im rebuilding a 302 out of a truck, but its got the pre threaded block to convert it to a hydraulic roller cam anyways. But when I got it the block was pretty rusty and the pistons had to be beaten to death to get out and all the lifters are stuck and only come out about 1/2 way, dont know if this is a common thing or not? I havent got measurements on the bore yet but I was looking at a 30 over kit and dont know if thatll cut out enough to even the bore out? Ive heard yes and no so I figured Id ask the real people, can you go 60 over on a 302? If so how hot will it run being constantly turned at 7000rpm?
RE: 302 rebuild questions
ORIGINAL: Bejiita
Well its easy to say that but I dont got money to spend boring 3 times(2 for this block and 1 for my other 302)
ORIGINAL: Bejiita
Well I got another one, but its an older one and I was hoping to go to hydraulic roller without drilling and tapping the other block, and Im building this in a shop class and dont want to fall behind because everyone else already has their engines fully disasembled but me lol. Do I need a hydraulic roller to spin to 7,000rpm safely and efficiently?
Accurate blueprinting for any engine takes time and equipment, and a necessity for getting the best in durability from your build. Doesn't matter if its reciprocating or rotary.
Short answer: no. You'll have no margin to rebuild if something happens to the engine.
Nudge-nudge, stomp-stomp, wink-wink answer: yes. And kits are already available for that bore. If you just want max displacement, the block was inexpensive, or just don't care if the block dies a little sooner, then yes, you can.
But don't overbore more than you have to. Get a Haynes or Chilton manual to check your out-of-round and taper limits.
And if you don't like the 'average mustang guy', don't come back. Who do you think hangs out here?
And DBZ sucked.
And DBZ sucked.
Well I guess Ill just use my other block since no one here knows what Im trying to get at,I agree DBZ wasnt very good I just like the name and have been using it for several years. I dislike the average mustang guy because everyone that Ive met that owns a mustang thinks they are super badass ****** because they can drive in a straight line. I was hoping to get a straight answer if 60 over was safe or not so thank you.
