Valve cover gasket...1.7 rockers...
question....I need to replace the valve cover gaskets so I thought I would get some 1.7 rockers and new springs...sooo:
1. How many more rpms will I notice in the powerband (and where)?
2. How difficult is the install?
3. Will it effect my passing emissions? (all other equip is in place...dang IL)
4. Is it worth the cash/trouble?...given that I have basic mods, intake, cat-back flows, pullies, and 3.73 in the mail (cant wait for it to get here!!)
RE: Valve cover gasket...1.7 rockers...
changing the valve springs with the heads on the car will require you to have an air compressor with a adapter fitting to allow you to put air pressure into the cylinder as you change the springs or else the valve will fall back down into the cylinder. you have to do one valve at a time and position the cylinder at top dead center and you may have to put a wrench on the crankshaft to keep the air pressure from trying to turn the motor over while you are trying to change the springs. as old as your's is, I would recommend you just pull the heads and send them out for a good valve job that includes installing new springs unless you really want to go to all the trouble for little benefit.
what is the advantages to getting new springs? thought they didnt make a diff, unless changing cam? thought just changing the roller rockers was about all you wanted to do with stock cam?
ORIGINAL: nemethjames1
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
