Timing question
RE: Timing question
the general rule of thumb is -1 degree for each lb of boost. unless if you have a timing retard setup. so if you were running 12 degrees of timing you should back it off to 3. once you have it running good you can slowly bump the timing up. just ensure if you hear detonation under boost that you get out of it. you should be able to settle on 6-8 degrees once you're done.
Calizic
08-28-2015 01:46 PM
