traction lok rebuild
i'm bout to get some gears and rebuild my rear end but i was wondering if the traction lok rebuild kit is as good as just getting a new one
i was looking at these and not sure if i should get the rebuild with carbon discs or not...
http://www.jegs.com/webapp/wcs/store...53282_-1_11219
RE: traction lok rebuild
id get two or 3 of the regular kits, and then change how you put the discs in(order), ihave a link to how to go about it, itll make it hook/hit harder... 94gtcoupe might have the link... i have it at home, im at class...
nope don't have the link (don't have links that i don't need lol) but the only thingthe carbon dics make a difference on is how long they last, the normal ones and the carbon discs grab just hte same...
with a conventional rebuild the discs go ddcddc (d= drive disc c= clutch disc) but if you go dcdcdc and add .01" to the shims on each side of the diff. you get aMUCH stronger grab and willnever spin one tire
ORIGINAL: 94gtcoupe
210 for an install? that better be gears, seals, bearings, clips, and labor to rebuild the diff.
so if i buy 2 of the kits and tell them that i want a specific order do you think they'd do it?
