Which is positive and negative?
RE: Which is positive and negative?
I tested the sensor with the motor turned off and the key turned to the on position, it's giving me different readings that seem more accurate. It's now reading at like 1.0v-1.2v with the motor not running.Should the motor be running or not-running when testing the sensor?
testing the voltage positive and negative will not properly diagnose a bad sensor. you need a control... like a pot of water with a thermometer in it. then rear the resistance chart and see what the sensor SHOULD be putting out, and compare it to what it does put out.
if the sensor gives false, or incorrect readings at two different temperatures.. its toast!
ORIGINAL: 92hatchLX
It's taped up and about 1/2 inch of wire is exposed before it goes into the piggyback connector. I'm going to retest it one more time just to make sure that I'm going going crazy. I ran codes on it too and the ECU isn't picking anything up it passes boththe KOEO and KOER.
Added: You could also invert the VOM probes, the only difference (if you have them inverted when reading voltage) will be, that a (-) volts will be shown on the display.....
lincolnshibuya
12-08-2015 04:37 PM
TfcCDR
09-14-2015 12:08 PM
