Gas ques..
Gas ques..
What do u guys think bout goin from 87 to 93(premium) in the 5oh's? The reason is is cuz i heard it gives ua lil bit more hp. Iam also goin to bump up the timing. Could this be bad for the engine inANY way?
RE: Gas ques..
advanced timing is what we like to consider a "free hp" mod.
If you push your timing from the stock 10° to about 14° your car can pick up anywhere up to 7-10hp.... its been proven
run some 89 in your car for a while to get all the 87 out, then put in a couple gallons of 89 in the car and bump the timing to 14°
If it runs fine with no pinging at 14° with 89, your golden, no need for 93... but should you need to fill witl 93, you wont have a full tank to deal with, you can just add 93 in and mix it up
RE: Gas ques..
it won't burn cleaner, the higher octane will actually produce more pollutants and other nonsense. i've always run it, even when i was stock. so don't think i'm saying that it is bad. i did it just for a higher quality fuel. but as stated above, raise the timing and pay the extra $4 dollars a fill up.
Matt's 95 Stang
10-05-2015 07:16 AM
