5.0 rotating assembly
I am assuming most the people know that the 87-92 pistons are forged & 93 are hypereutectic & for both types of engines the rods & crankshaft are cast. If you can only answer one please do so. Thanks in advance to everyone that helps.
1) What year engines are both the crankshaft & rods the exact same as the 87-92 H.O.?
2) Are the 5.0 & the 5.0 H.O. connecting rods & crankshaft different?
RE: 5.0 rotating assembly
the 5.0 and 5.0 HO crankshafts are different as the two engines have a different firing order. don't know about the rods but I imagine the 5.0 rods are stronger ones.
you can also call the Ford Racing Performance Parts hot line at 586-468-1356 about the other questions.
ORIGINAL: roundman
ORIGINAL: Isaac
no the camshaft is different, and the camshaft is what causes the need for a different firing order... aww roundy...
So you're saying the same crank shaft can have different pistons at the top when they need to fire in a different order. There are certain permutations that can do this with the same crank, but the timig gear would require a different indexing. However, I kind of suspect Roundy is right.
Yes that is exactly what I am saying, and while I see the reasoning in your post - your logic is flawed. The only thing that is changing the firing order on 5.0 vs the 5.0 HO & 351w is the camshaft. As a matter of fact, you can swap the camshafts between the two provided you change firing order. Remember the crank goes around 4 times for every firing cycle, that leaves room for another firing order. Why it was changed? I don't know Im I didn't engineer the motor, but thats the way it is.
And I did some research, the 50oz balancer was first put into use in '81 so as long as you get an '81+ crank your good. The rods appear to be the same from the very first 5.0.
you're right about the crankshaft but wrong about the number of times it rotates in a firing cycle, it only goes around twice or 720 cranshaft degrees in one firing order sequence. A 90 degree V-8 engine fires a cylinder every 1/4 turn of the crankshaft, so with 8 cylinders, it goes 2 revs not 4.
with the firing order for the 5.0 HO being 1-3-7-2-6-5-4-8 and the regular 5.0 being 1-5-4-2-6-3-7-8 it appears they switched the 3-7 and the 5-4 cylinders in the order. this gets away from the possible problem with two adjacent cylinders (#7 & #8) being back to back in the firing order which sometimes is a problem with induced voltage in the spark plug wires causing one cylinder to fire early if the wires are routed side by side and the insulation is bad.
ORIGINAL: mdvaldosta
my bad about the 4 rev's per firing ... twas thinkin 4 stroke at the time... sorry for strokin too much
