AGGRIVATING VIBRATION
if it isn't one thing its another....got the mini starter working thanks to mattdel. now i have a decent vibration at idle and all through the RPM range. i installed a new flywheel, clutch kit, pilot bearing, throwout bearing and retainer. the vibrations are while sitting still. the car is still on jack stands, so its not the driveshaft. any help would be greatly appreciated.....
RE: AGGRIVATING VIBRATION
well...while i was out there...i reved the motor with the clutch in and it didn't vibrate...when i let the clutch out completely...it starts to vibrate and makes a noise almost like a throwout bearing....the vibration won't knock teeth out, but it shakes enough to make me not wanna drive it to a big car show saturday...[:@]
something is definately wrong with the clutch/bearing setup. maybe get a new bearing, cuz you gotta take it all apart again anyway[:@]
did you do anything with the flywheel? improper torque specs?
