will this valve covers work
Old 02-23-2007, 09:41 PM
CrazyCobraSpeed
CrazyCobraSpeed's Avatar
Default will this valve covers work
they are for a fox it says... but i mean i have gt-40 heads shouldnt they work
http://www.latemodelrestoration.com/...1&comp=LRS
CrazyCobraSpeed is offline
Old 02-23-2007, 09:42 PM
stangman94
stangman94's Avatar
Default RE: will this valve covers work
i dont see why they wouldnt
stangman94 is offline
Old 02-23-2007, 09:45 PM
CrazyCobraSpeed
id like to know for sure tho... what else do i need gaskets and bolts??
Old 02-23-2007, 09:49 PM
I3atR!ce
I3atR!ce's Avatar
yeah they'll fit, and yes you need gaskets and hardware too.
I3atR!ce is offline
Old 02-23-2007, 09:57 PM
CrazyCobraSpeed
alright thats cool... the polish aluminum wont get nasty will it??? i dont want to have to polish it all the time.. i just use simply green and a brush if needed they spray everything down... will that worth with this??
Old 02-23-2007, 10:00 PM
stangman94
stangman94's Avatar
You could just paint your old ones its realy not that hard. Just sand your covers down with a 100 grits then a 180 and paint em with a high temp paint
Old 02-23-2007, 10:02 PM
90Lxstanger
90Lxstanger's Avatar
ORIGINAL: I3atR!ce
Agreed, most. maybe all 6 bolt vavle covers fit Ford small blocks, I belive 351 and up are 7 bolt?
90Lxstanger is offline
Old 02-23-2007, 10:14 PM
redmustang83596
redmustang83596's Avatar
Yeah those will work, there are different versions for fuel injected and carburated.
redmustang83596 is offline
Old 02-24-2007, 09:18 PM
burntpiston2007
I ♥ Acer
burntpiston2007's Avatar
95 is not a fox, but the motor is from the fox era. They should work. ive seen 95
projects w/aftermaket v/c. you might need a 1/2 inch or 1inch spacer!
burntpiston2007 is offline
mirandaandjimmy
11-16-2015 08:51 AM
YoungStangsMan
09-05-2015 07:01 PM
chrisdbassplayer
09-01-2015 05:30 PM
inyadreems
08-21-2015 09:10 AM
Elcameeeno
08-19-2015 11:19 AM
Quick Reply: will this valve covers work
