those thoseCam help
Old 02-23-2007, 10:28 PM
grayfox92
grayfox92's Avatar
Default those thoseCam help
I just got a pair of 185,61Cc AFR heads. which would the perfect cam
for these heads on stock 302/5.0L
grayfox92 is offline
Old 02-23-2007, 10:37 PM
ZachW04Stang
ZachW04Stang's Avatar
Default RE: those thoseCam help
Have you notched the pistons. Your probably going to bend the hell out of all your intake valves with any cam with those 2.02 valves. Those are high flowing heads and require a cam to match the power band. You could get a custom cam which would be made for your setup or you could get an off the shelf cam for the power band your looking for. No one can tell you what cam will be perfect for your setup.
ZachW04Stang is offline
Old 02-24-2007, 12:50 PM
grayfox92
grayfox92's Avatar
What you think about the 165,61Cc pistons need to be notched? or same thing as 185s.
sorry about the dumb ? i'm new
Old 02-24-2007, 02:34 PM
r.barn
r.barn's Avatar
piston dont not need to be notched for 165's
www.camshaftinnovations.com
get a head/cam combo from them, save headaches and guess work
since they were made to work together to YOUR wants and needs.
or just a custom cam from them with AFR 165's
Canfields flow better than AFR's for the same money.
r.barn is offline
Old 02-24-2007, 06:39 PM
burntpiston2007
I ♥ Acer
burntpiston2007's Avatar
whats the rest of your set up look like
burntpiston2007 is offline
Old 02-24-2007, 06:47 PM
grabbem88
grabbem88's Avatar
pistons have to be notched....for the best cam i'll tell ya what after jay allen did my cam/springs my comp cams 544/544 224/232 cam was a chump compared to his...he knows what's the best,and i'll leave it at that
grabbem88 is offline
Old 02-24-2007, 09:06 PM
grayfox92
grayfox92's Avatar
E303
bbk ssi w/75 tb
70 maf 19lbs stock injectors
long tube headrs, 3in flow masters
AJE fornt end drag kit
