set me straight here
Hey all, can someone either tell me how or point me to a good write up on installing and properly setting up stud mount roller rockers please?
thanks a lot
1988 5.0 GT world heads E303 cobra upper/lower, looking for a reasonably priced 1 inch phenolic spacer....msg me if you know.
thanks a lot
RE: set me straight here
This should help: http://www.compcams.com/Technical/In.../Files/250.pdf
I hope those aren't world sr heads and a stock short block.
Here's another write up. This is info from Crane Cams..
http://mustangpartstech.com/AdjustingRollerRockers.html
Thought I would ressurrect this thread rather than start a new one, my first attempt at adjusting rockers failed and I'm not sure why. Turned engine over by hand(clockwise as you look at the front) until the exhaust rocker on cylinder #1 started to open, then adjusted intake rocker on same cylinder, I got to zero lash no problem, however the end of all possible adjustments was less than a 1/4 turn away and I don't see any set screw or way to lock the rocker nut in that position(crane blue racer 1.6) I went on and cranked the engine over till the intake I just adjusted started to close, then adjusted the exhaust valve the same way with the same results. I noted several cylinders where I ran out of adjustment at or just beyond zero lash and severeal where I could adjust the 1/2 to 3/4 turn reccommended. Are my rods to short/long? It is a stock block all redone bored to 306, brand new windsor junior heads, E-303, crane rockers with studs/plates blue racer 1.6s, and stock length hardened motorsport pushrods, sorry to write a book but it would be very bad if I screwed this up as Mr Mustang is tired of not flying down the road.
thanks
thanks
Hm, I installed a bunch of what looked like double ended bolts in the heads, thought those were called studs. Guide plate followed by stud, insert rods, place rockers on stud and make sure both rod ended are seated right, clue me in here, where did I mess up?
I didn't see any allen key, I will look again tomorrow though. Maybe someone could post a picture of pedestal mount and stud mount so I can see the difference and maybe learn something!
thanks guys
thanks guys
