PLEASE HELP.....Timing Cover!!!
Man, I've been working on this stinking thing for at least 4 hours. I've taken out all of the bolts (I'm positive) and the stupid thing won't budge. Its a little loose around the top and the right side, but the left side where it meets the oil pan isn't going anywhere soon. I have no idea how to get this off. I'm not really in any hurry, but its starting to seem impossible. Any ideas?
RE: PLEASE HELP.....Timing Cover!!!
ORIGINAL: mattdel
there is 2 bolts going up through the pan that thread into the cover
Take those out, the cover will come off as well.
EDIT: Maybe the RTV is holding it back? Double check to see that every bolt is out...you do have the balancer off right?
white fox, I'm notgetting what you mean. There are 2 bolts the go up through the oil pan to the cover. Ive taken these out. Is there another one I missed? I didn't see any.
ORIGINAL: mattdel
put a screwdriver in there and tap it down inbetween the block and cover.
I would just tap it with a rubber mallet. You have your water pump on it still?
