EFI to Carb
RE: EFI to Carb
i imagne the engines for the chevs, chryslers, fords and amc's were engineered by the same peeps anyhow...my great uncle worked as an engineer for both ford and chrysler at various times during his career.
RE: EFI to Carb
Granetelli sells a pickup that goes in place of the pump for $95. It has 5/8 feed tube and 3/8 return tube. It should support a huge amount of hp and won't be a huge restriction like the stock pump would be.
RE: EFI to Carb
I'm gonna drop the tank tomorrow and see if I can modify the fuel pump to just alow fuel to flow through it. If not, i will be buying that tank insert...i want to get away from using an electric fuel pump.
RE: EFI to Carb
You can remove the pump from the assembly, and take some fuel line (& hose clamps) and make a pick up. I took a metal, double male connector and put it at the end of the line so wont collaps when sucking up fuel. Mine works fine.
RE: EFI to Carb
ORIGINAL: Evil_F
Just curious....did you use the black rubber fuel line or that clear plastic "aquarium" line?
RE: EFI to Carb
ORIGINAL: Li0nHart
RE: EFI to Carb
judging by how wide the engine is in the bay..i don't imagine i will be working on anything once its in....wonder if i could shoe horn a cam from an early 80's datsun or hyundai1.8L into my block....i do have a welder....
