Need help with turbo.
http://cgi.ebay.com/ebaymotors/Ford-...QQcmdZViewItem first is this turbo kit any good? Its really cheap . Also I have no clue about turbo. But i hear its better then a supercharger. If i went twin turbo Say i had two 50MM turbos. dose this mean i have a 100MM turbo system? I want to push 700hp. Imbuilding a car right now. But want to see how much a turbo kit is going to cost me first. Im looking to spend 17-1900$.. but whats cheaper? id like to be able to get 175-200hp out of a turbo kit. what ever i buy. Thanks guys Andy
RE: Need help with turbo.
i wouldn't buy it, and if you think you can buy a turbo setup for 17-1900 then you need to reconsider. they cost money, and you get what you pay for. head over to turbomustangs.com for all the info you need
I understand. its going to be a long process. but i mean what kinda turbo kit should i buy to make 150-200 hp? and it can be twin or single. twins look good but what ever makes it run good.,
ill buy a used turbo kit. just i dont know what size turbo n stuff to use. any one have any good tech sites on turbo? like what MM means and what waste gate means and what T3 T4 flange means?
Forced Fabrication
733 Windham St.
Dayton OH 45404
937.533.1730
Latest News:
79-93 Fox Stage I (release date Jan 2005)
Base MSRP: $1999
Designed For
Single/Twin
Target HP
Maximum HP
Turbocharger
Largest Turbocharger
79-93 EFI
Single
400
900
60-1
T76
BOV/Bypass
Wastegate
Headers (material, sizing)
Downpipe Size
Intercooler
N/A
38mm Tial
16g mild steel, 1.5" aluminized mandrel bent, 3/8" flange
3"
Bar-Plate core is 24x10x3.5"
2.5" inlet, 3" outlet
Intercooler Tubing (size/material)
Boost Controller
Fuel Compensation (pump, FMU, custom chip, etc.)
2.5"-3"
N/A
N/A
Miscellaneous Features
This is a base kit that can be run with stock components and general upgrades like you would use with a supercharger Kit can be upgraded with any components available in Stage II Kit include all gaskets hoses T-bolt clamps. Crossover connection and downpipe are v-band. Passenger side Turbo
Retains all accs. air pump removal required 10-12 hrs install 1 yr complete warranty lifetime on design and stress of piping components lifetime on silicon hoses for original owner.
Options
ANY Component can be purchased as a kit or individually
Extreme package Tuning kit: 42lb inj., Calibrated airmeter, 255 intank,
SCT custom chip $950 ($50 off if purchased with kit)
Intercooler and piping $600
Turbo upgrade T70 $100
Ceramic coating $400
BOV $130+
Stage II $2999 add $900 for complete extreme package, replaces 60-1 with T70 and adds ceramic coating and Frontmount Intercooler with Turbosmart BOV
Extreme package adds 42lb inj., airmeter, 255 intank, chip
2Grand? thats not bad but i duno i dont understand thies specs
all u need for a fox turbo system thats bolt on www.hellionpowersystems.com
