Water pump leakin
RE: Water pump leakin
If it is coming out of the weep hole, you need a new water pump... That hole is used to bypass water out of the pump in case the seals on the bearings of the pumps go out... Best thing to do is go to Advance or any parts house and pick you one up for 25 bucks or so... Good luck
ORIGINAL: OnyxCobra
what is the weep hole?
Even though this isn't a mustang pump, you can see the hole here by the white dot.
ORIGINAL: OnyxCobra
my edelbrock victor water pump leaked right after I put it in, turns out the heads of the 2 bolts they use to hold on the backing plate are too wide, had to grind a 1/8 inch off them
but a new pump isnt expensive and will give you a piece of mind.
jwog666
12-27-2021 08:09 PM
