Gaskets seals and what no for H/C/I swap
#22
RE: Gaskets seals and what no for H/C/I swap
ORIGINAL: CrazyCobraSpeed
im having trouble finding this complete kit your talking about... what section is it under?
ORIGINAL: 92hatchLX
Just get the complete ford racingengine gasket set off of Summit.
#23
ORIGINAL: 92hatchLX
Hell, I've got the old box laying on the floor lemme see if I can find a part# on it, if not I'll find it on Summit for you.
thanks bro... im not very familiar with summit so i may have just been doin sumthan wrong... appericate the help tho
ORIGINAL: 92hatchLX
#24
frpp gasket set
you really need to get in contact with thumper because pushrods and lifter aren't apart of your heads and you will want tonew of both. RTV is great (high-temp stuff) just rememberto use a real thin coat oryou can also go with permatex gasket sealant. Just dont put eitheron your head gaskets.
#25
http://store.summitracing.com/partde...p;autoview=sku
There's the set that I used when I tore apart my motor. Good stuff IMO.
#26
ORIGINAL: 92hatchLX
Thanks for the link
ORIGINAL: 5.0liter_rice_eater
frpp gasket set
frpp gasket set
#28
i am also planning a H/C/I swap and am confused about sealants. I heard that sealant should be used on the head bolts that pass through the water jackets, what kind should i use for this?
Also i see many people say to use gaskets between the lower intake and the block and others say just to use black silicone. Which is better?
#29
ORIGINAL: 1991LX5.0
my walk through i have says to use gaskets with high tac yellow silicones or somthan like that i think... i got a walk through but it doesnt give much info on the types of sealent... here is hte link to the walkthrough tho... its a really good walkthrough http://www.allfordmustangs.com/techa...intakeswap.pdf
