Gaskets seals and what no for H/C/I swap
#31
RE: Gaskets seals and what no for H/C/I swap
im thinking of also stroking in 347... what do u all thing... how much work is that.. i no id have to get an engine shop port and notch out hte bottom
#32
I used Red threadlocker on my studs. Just go w/ Felpro gaskets from your local auto parts store...they'll be cheaper. Felpro PT9333-1 is the head gasket #, IIRC, and the stock manifold gasket set is fine, even w/ ported heads. In fact, I ported mine to that gasket..... You'll need some red or black RTV for the front and back corners of the lower intake, even if your kit has the rubber front and rear gaskets. Don't be stingy w/ it, I had to redo mine b/c I didn't put enough and it was leaking oil onto my timing cover.
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
