Taller tires, what will it do?
Old 02-26-2007, 07:48 PM
5.0stanger
5.0stanger's Avatar
Default RE: Taller tires, what will it do?
Okay then, so should I get the 26", 27" or 28"?
5.0stanger is offline
Old 02-26-2007, 07:52 PM
OnyxCobra
OnyxCobra's Avatar
Depends what you want, sometimes people running a low gear will use a bigger tire to help offset it a little. If you want the stock size just go with 255/55-15, if you want a 27" tire go with 255/60-15. If you want a 26" tire thats 275 wide go with 275/50-15, and so on.
OnyxCobra is offline
Old 02-26-2007, 07:54 PM
5.0stanger
5.0stanger's Avatar
See, that's the thing, I don't know what to run.
Old 02-26-2007, 08:02 PM
Mowin8603
Mowin8603's Avatar
if its just for the track and looks dont really matter whats the problem here? the size difference between your setup right now and whether you go to a 26,27,or 28 tire for the track isnt really going to hurt anything at the track. [/align][/align]id say do a 255/55/15 that is if you have a set of 15" wheels for the track?[/align]
Mowin8603 is offline
Old 02-26-2007, 08:06 PM
5.0stanger
5.0stanger's Avatar
I have some 15" 10 holes. The tire I want (MT ET streets) only come in 235/60/15 and 255/60/15...not a 255/55/15.
Old 02-26-2007, 08:07 PM
Mowin8603
Mowin8603's Avatar
then id say do a 255/60/15[/align]
Old 02-26-2007, 08:27 PM
notch5oh
notch5oh's Avatar
i agree, 255/60/15
notch5oh is offline
Old 02-26-2007, 08:39 PM
AdderMk2
Banned
AdderMk2's Avatar
if they are for track only, it doesnt really matter. Personally, I think putting drag radials on 10 holes is a waste of time, but hey, to each their own. I would rather have a 15x8 with a 275/50/15 and run the proper tire height.
AdderMk2 is offline
Old 02-26-2007, 08:51 PM
5.0stanger
5.0stanger's Avatar
Isn't the 275/50 the same height as the 255/60? And why are running DR on 10 holes a waste?
Edit: my bad, 275/50 is 26" tall
255/60 is 27" tall.
Old 02-26-2007, 09:03 PM
gearbanger
gearbanger's Avatar
ORIGINAL: 5.0stanger
i got the ten hole 275/60/15 and it works fine for me.... great grip
gearbanger is offline
Quick Reply: Taller tires, what will it do?
