HELP CAN NOT HIT WOT!!!!
ok i recently put a edelbrock performer rpm2 on my car... but i cant hit wot and the throttle feels weak... looked at ther throttle cable and it all seems good... any sudjestions on what to to do??? thanks.... oh and for those that has bien with me on this the car sounds great will get clips of it soon...
RE: HELP CAN NOT HIT WOT!!!!
Isn't that RPM2 upper and lower a bit too much for stock heads? Obviously you put it back together different than what it was, I'd double check it. Or you can try bending your pedal, or putting a spacer on the throttle cable.
You may want to check this fix, it also applies to earlier models........ http://www.mustangworld.com/ourpics/fcar/99pedals.htm
Easiest thing to do is get someone inside the car and have them push the gas all the way to the floor (car not running obviously), and the when it is at wot, see if you can open the throttle up more by twisting the linkage at the throttle body... Might wanna give that a try
ORIGINAL: kev2369
