valve cover Question
RE: valve cover Question
Throttle body placement is the main difference... So it makes the linkage and egr move along with it... A lot of stuff will interchange, it just has to be modified... Everything bolts on the same though
No problem... You should be able to use most things listed for 86-93, like intakes and such.... A 94-95 have a different throttle body and REQUIRE an elbow adaptor that is available from trick flow, professional products and some others that will let you use the better intakes that are for 86-93's.... Good luck
Yeah, polished aluminum = better heat displacement & lighter... I bought some inexpensive chrome ones (tall ones) from Ebay. They are single ply stamped steel. They are still light and work. No complaints about them here.
in order to make it work you have to shave the bottom of throttle body alittle and cut of the bottom of the egr and the bottom of the manifold were the egr bolt up to . that will leave you with on bolt on the manifold for you to bolt it up to . it is work i know i did it .
zanemoseley
09-06-2015 12:58 PM
