89 to 79 swap
Old 02-27-2007, 10:20 AM
ZZmustang
Banned
ZZmustang's Avatar
Default 89 to 79 swap
Me and My Daughter are just starting a project. I have a 89 GT and a 79 notchback (6).
I want to put the running gear from the 89 into the 79. That’s all pretty easy, Now, I want to put two 4 barrels on the 302 instead of the throttle body manifold.
What changes do I have to do to the 302 to get it to runwith carbs. Intake, carbs, Distributor, (especially distributor) . Also, anyone need some 89 GT parts. (New gray cloth back seat) .
Thanks
ZZmustang is offline
Old 02-27-2007, 12:30 PM
boof1027
boof1027's Avatar
Default RE: 89 to 79 swap
I don't think a 302 will handle dual 4 barrels. I have a 650 dual line on mine and it tends to run rich when I kick the 4 barrels in. I bought a new dizzy for a 71 model 302 and put in mine that way it is points style (no computer). Intake I bought a holley street dominator. I am happy with the setup. Depending on your coil you may need a ballast resistor. They are like 7 bux. If you have any quesdtions just pm me and I will try my best to help. I need the rubber moldings that run along the middle of the door. PM me a price shipped to 41234. Piano wire takes tehm off easy.
boof1027 is offline
Old 02-27-2007, 08:09 PM
PJB
PJB's Avatar
Thats way overkill, especially for what Im assuming is a stock 302.
The Mopars with a 440 only came with a 6 pack (3 2 barrels) and thats a big block.
PJB is offline
Old 02-27-2007, 09:49 PM
Evil_F
Evil_F's Avatar
It can do dual fours. Even know of a guy with dual fours on a 289. You have to tune them.
Evil_F is offline
Old 02-27-2007, 09:51 PM
ih8chevy
ih8chevy's Avatar
dual 4's are too much for a mild 302, the only way u would need them was if u had over 500 wheel and even then u can do fine with a single carb. i dont think there are many dual 4 intakes, but the things u need tochange are the intake and dizzy, the rest will take to a carb fine.
ih8chevy is offline
Old 02-27-2007, 10:03 PM
notch5oh
notch5oh's Avatar
if you want the look of dual quads, use really small carbs, like 400 cfm
notch5oh is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Bokeo
10-10-2015 08:28 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
UrS4
09-30-2015 10:13 AM
Quick Reply: 89 to 79 swap
