HELP NEEDED!!! wanting info on putting carburated 302 in thunderbird turbo cpe
what i have now is an '87 thunderbird turbo coupe that is blown up and i have a stock carburated 302 out of a stang that i would like to drop in. i need to still buy a intake and carb for it, but i also wanted to upgrade cam, butim clueless on what to put in, im told to put an e303 cam but not sure what move to make there either. do i need different motor mounts, how hard is this to wire up.... like i said im clueless on what i must do here.
can anyone help me in the right direction? thanks
RE: HELP NEEDED!!! wanting info on putting carburated 302 in thunderbird turbo cpe
umm Ill trade you a 82 GT that is already carbed and running for it! lol I want one of those turbocoupe thunderbirds so bad because I have a perfect motor waiting to go in one but havnt found a good one yet. It shouldnt be thaat hard to do
http://www.jason.fletcher.net/
That site has alot of your answers to do it on a mustang which is basically the same thing in a sense but you should put a turbo 4 back in it
lol my car needs bodywork and needs a floorboard on the drivers side that I have yet still to put in but I have it and it needs the sway bar welded back in the frame lol whats wrong with your car? Im from aboot 300 ish miles away ish in stroudsburg
send me pictures and ill upload some of the bird..... it ran fine oil pan gasket leaked, and then i ran it dry, forgot to check.... and i think a bearing went..... currently its automatic but the other short block came with a clutch, pressure plate and bell housing..... just missing the trans itself
Im the carb master.... any Q's just ask. I like Holley type carbs over the Edlebrock design, but I have set up several Edlebrock as well. I use Barry Grant carbs. they are the same design as Holley but cost a bit less.
Have fun. Turbo Coupes are very complex when it comes to wiring and the computers. You have a lot more to worry about when putting a carb in it.
ORIGINAL: TBird232ci
Matt
ORIGINAL: boof1027
He will ditch all the smog and emissions controls if he is going to carbs.
Matt
Matt
